Televison & Video Logo
Posted on Nov 07, 2008
Libary view for Samsung DVD SH853M
Hi
When I record on the hardrive of the Samsung DVD SH853M the libary view shows the name of the channel and time recorded rather than the program name. Is there an option to change the view?
Thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
338
Points
No, I'm afraid not - this player simply does not offer that feature. Amazon reviews are very negative about the product.
Wiring diagram for a samsung dvd-sh853m
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
3helpful
How do i sync my new iphone 5 to my itunes music libary
All you need to do is go to your music library and under the edit button on the top tool bar select "select all" then click "copy".
Then go to your iPhone 5 music library under the "devices" section in ITUNES and click on the MUSIC folder, once your in this folder select "paste" under the edit menu. And your music will then start to transfer.
More sources: Sync iPhone 5 to iTunes music libary
1helpful
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
1helpful
2answers
Is there a way to listen to movies on 1st gen Itouch w/o headphones?
No only the 2nd Gen+ itouches have the speakers built in, generation 1 itouches dont have speakers, so you must use the microphones. (The speakers arent that loud anyways.)
Can't detect the memery card.
my mp3 player is not working. there is no option to choose from the songs in the libary.
Samsung HDD SH853M doesn't work
What type of cable are u using to connect the TV and player.
Check those first, and reconnect if in doubt and post back
Rifaa
2answers
I keep getting error2131
I have got a samsung R700 and every time I try to burn a cd from the playlist it comes up with "error2131"
Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
1helpful
3answers
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
