You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
try to find some thing with in its rms is the rule of thumb try looking around ebay i just picked up two A2300HCX great place to find car audio Hope this helps............
