Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to fix Exception Processing Message c0000013 Parameters75b6bf7c 4
Defrag disapear, windows no disk always appearing.
  • 2 more comments
  • race08 Dec 12, 2008
    I installedRCA Easyrip to load music in a mp3 player. I use a usb port on the card reader. now when I open Easy Rip I aget the Exception Processing message c0000013 Parameters 75b6bf7c 4
  • brute8463 Jan 21, 2009
    exception processing message c0000013 parameters75b6bf7c 4 75b6bf7c 75b6bf7c
  • anshad1 Jan 26, 2009
    I have the same problem
  • hafisin Apr 03, 2009
    me too have the same prob
Posted on Nov 10, 2008
SOURCE:
Windows disco non presente exception processing message c0000013 parameters 75b1bf7c 4 75b1bf7c 75b1bf7c
Wrong removable disk/media letter in My Computer.
Go to Start / Computer management / Disk management / in there check that the first partition on the hard disk is C and none of the other partitions/removable media disks have assigned the C letter. If one of them has it (or none at all) then right click on it / Change Drive Letter and Paths... / Change / select another letter / OK .
May 23, 2010 | Microsoft Windows XP Professional SP3 Full...
Describe your When I try to load drivers for a Canon scanner I keep getting Windows - No Disk Exception Processing Message c0000013 Parameters 75b6bf7c 4 75b6bf7c 75b6bf7c Problem
HAVE YOU USED THE LATEST DRIVERS THAT ARE ONLINE AND IS IT LISTED FOR YOUR WINDOWS VERSION, I KNOW VISTA HAS SOME PROBLEMS WITH USB DEVICES AND RECOMMENDS A HOT FIX.
Feb 26, 2010 | Microsoft Windows XP Professional SP3 Full...
Computer error problem
http://www.fixya.com/PostAnswer.aspx?thid=2692939
drea_mike67 on Jul 31, 2009
a message saying windows-no dis exception processing message c0000013 parameters 75b6bf9c 4 75b6bf9c 75b6bf9c then it says cancel try agin contunue and i push one and it just keeps coming back constantly.
Friday, July 31, 2009
Hello drea_mike67,
There may be any number of storage device faults causing the no disk exception error message. For instance, a usb device may have been removed without choosing the 'safely remove hardware' option. If that's the case then reconnect the usb device and choose 'safely remove hardware' (bottom right hand corner of your PC screen), and then remove the USB device.
If the error message still comes up then try using the device manager in the windows control panel like this:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select System
•Select the Hardware tab
•Select Device Manager
•Look for disk drives or other drives that are not used or recognized...
•Right click the device(s) and select uninstall
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 31, 2009 | HP Computers & Internet
Windows - no disk exception processing message c0000013 parameter
Here is a site that fixes this problem with the error:
http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
For your memory problem you will need to add more physical memory to your system. Physical memory is a chip that is installed into your computer. Requires that you open the computer case and install the memory chip.
Jan 07, 2009 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
Error message
"UPDATE - summary added, history moved to end: This problem seems to be caused either by malware (virus or spyware etc), or by software following a Windows update or some other software installation or uninstallation (particularly HP, Norton or QuickTime software) trying to check for removable media that isn't there (e.g. disc in DVD drive or card in card reader), when it shouldn't be doing that check."
source: http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
another tip try running "search and destroy"
Dec 31, 2008 | Dell Dimension 4500S PC Desktop
WINDOWS- NO DISK
ooh...not good..looks a lot like a re format issue
got back up for that SonY?
Feb 20, 2008 | Sony VAIO VGN-FS840/W Notebook
Error message that comes up on computer and i cant get rid of it
The only way to get rid of it is to re-install ur operating system..
Goodluck,
Don't forget to rate me as fixya..
Jan 28, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
1,185 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
