Battery lost so quickly it only lasts half a day now. Had phone long time with no problem. Was fine until I connected to internet and wifi. I am not using it really but need it on just in case i need it for work. How do i know if something is running in the background? How can i find out and switch it off without switch internet access off all together?
All phones use more energy when connected to WiFi.
In order to preserve battery life, shut down your WiFi unless you need it.
Find Settings>Wireless and Networks , and uncheck the WiFi box.
Testimonial: "Thanks all for your help. It turns out wifi was continuously roaming, battery life seems much better now i have turned it off. Thanks"
SOURCE: I want to know how to transfer files from computer
You can transfer files and media via bluetooth or by using the cable that also is used for your charger.
Just connect the cable to a USB port on your computer then plug it into the charge port on your phone.
When you get a little USB symbol in the top left of the phones screen, tap it and drag it down and tap Mount.
You can then access your phone and its files via "Your Computer"
SOURCE: charging error, stop charging! with "!"
I have had this problem before so dont worry, i found that i had to take out the chip and batery and air it out aswell as the the place were the charger fits, place them back in and try to charge up again.
SOURCE: Sony erricson w705, wont charge the battery, it
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
SOURCE: how do i put music from my computer files onto my Experia X 10
no just plugin the usb and do the following things mine is loading now so later i can tell you what to do but first solve it for yourself or find a tutorial if it wont work write a comment back or send me a message my email is [email protected] so i hope you can fix it for yourself bye
SOURCE: I have a new Sony
You probably have multiple apps running and don't know it!!!!! My friend suggested this to me and so far it has helped.... I downloaded Advanced Task Killer and I "kill" everything that I'm not using. The only thing that bothers me and I wish I could figure it out..... if I check this task killer once per hour, there are so many apps that are open that I didn't even use. I'm not sure why this is happening and havent had a chance to figure it out. But I hope this helps, I can be long winded for nothing so.....there's my two cents, hope it works out for you =)
