When I go onto the address 192.168.1.254, where do I disable Upnp?
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
SOURCE: upnp help for ps3 netopia router
Playstation Guides ( PS3 ) to change from NAT3 to NAT2...
Guide1 or Guide2 or Guide3
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at [email protected] on add me i believe my ps3 thing is ADV_WARfighter
SOURCE: How do I disable the
if you have the manual with the unit locate where is the reset button then push it for 10 sec.
