When i enter the USB into my pc the message displays" one of the USB device attached to this computer is malfunctioned, and window does not recognize it." what do i do now plz give me some idea so that i could function my mp3 properly... i m neither able to charge my MP3 not able to download any songs. plz help me
Hi Zoooya.
try this.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
even though the device is not present, causing the said error.
or this.
Try the steps below:
1. Make sure you update to latest BIOS.
2. Reinstall USB controllersFirst, please disconnect all USB devices and then perform the following steps:
a) Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
b) In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
c) Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
3. If the above steps cannot resolve the problem, try the steps below:a) Turned the laptop off, unplugged it.
b) Pulled out the battery for a few minutes.
c) Then power on the laptop.
Make sure the USB device is working, try changing to another USB port.
5. Also, you can try in-place upgrade your system or system restore from the Windows Recovery Environment (WinRE)
At boot-up, Hit F8 --> Repair --> System Recovery Options Window --> System Restore.
or this link if you need more info on this matter.
pc one of the USB device attached to this computer is malfunctioned and...
SOURCE: Samsung YP-K3 MP3
To reformat your MP3 player. You need to connect first your device to your computer then under my computer right click on SAMSUNG device under removeable devices then click on FORMAT. Hope this helps
SOURCE: Samsung YP-K3 mp3 player requires driver but I have no cd!!
the samsung website does have it...just type in your model number when you get to the 'download center', which is located under 'support'.
go here: http://www.samsung.com/au/support/download/supportDownMain.do
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
SOURCE: SAmsung YP-K3 MP3 player - Corrupted library ? cannot delete songs or synch
i would like to download other songs but i dont know how?and i have to delete all of them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: i need the drivers
Support page overview for all YP-K3 players:
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP00&searchWord=YPK3&searchInputBox=YP-K3
Select the matching device from the list.
On the next page select the tab Downloads :
For computer software EMODIO and MULTIMEDIA STUDIO select Software and download the required execute file.
Firmware for the player can be selected under Firmware: download the zip file and look under Description how to perform the update.
