Press set button repeatedly -you get timezone mode
and change your wished time zone and select your zone
then press set button to normal mode and adjust the current time.
kindly gave your rating after you read this.
Please go to your browser and type in the information line Atomic Clock directions. All of the companies that produce this type of clock are listed. I believe SKY Scan has its directions ready to be opened when clicked on! GOOD LUCK!
If this model has a DST switch on the back, make sure that it's turned ON. If there's no DST switch you can force a manual change by changing the time zone setting, but you'll need to do that twice a year. Also note that if the clock is more than two years old, turning the DST switch ON will make the clock conform to the old DST changeover dates.
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
There's no downloadable manual, but the manufacturer has it on a page here. As for the time changing overnight, make sure you have the right time zone set. It's probably wrong now, and the clock is resetting itself each day to what it thinks is the right time.
press set button repeatedly -you get timezone mode and change your wished time zone
and select your zone then press set button.
