Zodiac Pool Systems Jandy Legacy LRZ Pool Spa Heater 250K BTU Digital Natural Gas Polymer Headers Cupro Nickel LRZ250EN Logo
chris hopkins Posted on Mar 24, 2012
Igntion lockout code on jandy legacy lrz250en
Getting ignition lockout code on jandy legacy lrz250en
Why won't my new lrz start
need more info if wired correctly yo have a display you have correct gas pressure check wiring first if not wires 220 you must change thing see a professional
How too reset or clear controler
find faults in menu then hold down button for 7 seconds it will clear the faults
2answers
Ignition lockout code
what is the error code in display, did u reset the board by turning the power on/off
2answers
1-water flow ? gas related , is propane or natural gas ?
I have a Jandy LRZ250EN pool heater with a "fuselink' fault. The manual tells me to check the fuse or for loose connections. Fuse is good and I can't find any loose connections. Any...
If you find a schematic and a volt/ohm meter you may be able to trace through the safety circuitry. If you get stuck I will try to answer further questions.
Top Zodiac Pool Systems Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Zodiac Pool Systems Pool and Spa Expert? Answer questions, earn points and help others
