The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
SOURCE: Nikon D60 Screen failure when SD Card inserted
You can try other SD card , or insert your SD card in other camera to check it out which part have problem first.
SOURCE: Nikon D80 Exposure Count
Could it be that you are set in the "highlight" view? Use the round selector in view mode to change the views.
SOURCE: Sd card won't click into place on my Nikon d60
maybe theres a foreign object on the SD slot, it happened to my d60,
