Looks like your phone is locked. where did you get your phone from? was your phone working with your sim card or some other network previously? try inserting the sim card if your phone already had a card in it. if it works with that sim and doesnt work with other sim then your phone is a locked one. you need to unlock it and use it with other sim card. you can unlock it using codes. you can get the codes from Unlocking4U.com else if other sim card too didnt work in your phone then your phone has a problem and do take it to a nearest service provider.
SOURCE: my phone says inactive sim on my c905 but the sim
Check your Band setting on your phone. 900mhz/1800mhz or 1900mhz/850mhz
-Charlie S.
SOURCE: sony ericsson c905 no network coverage
Hi
Thanks for using FixYa. Please check the sim card first because it might not be making good contact to the prongs. It's not the phone causing the ‘no network coverage’ issue, it's either the sim needs to be removed and wiped off with a soft cotton material and then reinserted or it's the network having problems itself. Also try the sim card in another phone. If it works, then the problem is with the handset. If the sim doesn't work in another handset then contact your network provider to get the sim replaced. If it is still under warranty you'll need to take it back where you purchased it from to get it repaired or replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: My sony Ericcson W995 which
Its just started sayin no network coverage after i turned it ooff and back on.and when i connect the charger it says please use a sony battery?!?!?!?!?!?! wats happnin,had ths w995 for 6 days!!!
SOURCE: my sony ericsson k800i phone has a problem with signals
hello
the problem is with your phone's hardware
SOURCE: my sony ericcson t700 has no network coverage
HEY HI BUDDY....
THIS IS THE PROM\BLEM CAUSED BY VIRUS,WHICH ENTERS UR MOBILE WHILE YOU ARE TRASFERRING ANY FILES FROM OTHER MOBILES THAT HAS BEEN AFFECTED BY VIRUS......
THE BEST SOLUTION IS TO REINSTALL THE SOFTWARE AT THE NEAREST SONY ERICCSON SHOW ROOMS....
YOU WILL NOT BE CHARGED IF YOUR NOBILE IS RUNNNG IN WARRANTY....
THAMK YOU...GOOD DAY..
