A
Anonymous Posted on Mar 23, 2012
Xerox workcentre 5775 doesn't send or receive faxes
quick xerox
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 15, 2017
quick xerox
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6883
Points
Data Encryption / Data Description progress 1 hour xerox 5765
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Apr 30, 2008
SOURCE: Can receive faxes but are coming through partially or distorted.
Most receive problems relate to phone lines, But yours doesn't.
I would start here.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Left] or [Right] arrow button until 'Memory Clear' is displayed.
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select one of the following items to be cleared from memory:
    • System ID: Clears the fax number and name from the machine’s memory.
    • System Data: Restores all options that can be modified to the factory default.
    • PhoneBK / Memory: Clears the speed dial or group dial numbers stored in the machine's memory. In addition, all scheduled job operations that have been reserved are canceled.
    • TX-RX Journal: Clears all records of fax transmissions and receptions.
      NOTE: To exit without clearing the item, press the [Menu / Exit] button.
  5. Press the [Enter] button.
  6. If necessary, repeat steps 4 and 5 to clear another item from memory.
  7. Press the [Stop] button to return to the Standby mode.
A
Anonymous
  • Posted on Apr 09, 2009
SOURCE: i can't send or receive a fax
At the very least it should send a fax, without doing anything at all, but having it plugged into a phone line. Are you sure the line is good? Does it have a, "on Hook mode" or a button to press to get a dial tone? Otherwise, plug a telephone in and make sure there is a dial tone. Also it could be the cord itself, or has somebody conected it to the wrong jack on the fax machine? These are the things I suggest to check.
Anonymous
  • 112 Answers
  • Posted on Sep 19, 2009
SOURCE: Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
RHanson
  • 193 Answers
  • Posted on Dec 03, 2009
SOURCE: Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Anonymous
  • Posted on Nov 01, 2010
SOURCE: Xerox Workcentre PRO 635, 645,657 Memory Error
error #22
2answers
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Cannot send or receive faxes
This problem might be the moden board, or main board, or both.
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Promblem with xerox printer
This is solved with if you do a clear all Memory procedure under the Maintenaince settings
Replace Drum
k24674
ADMIN Andrew
ADMIN Andrew
