I purchased a Belkin .3fa Wireless Router. I have already plugged all the proper wires into the Tower and I can watch Netflix on my computer just fine but I want to watch it downstairs that's why I got the Wireless router and I can't seem to get connected properly please help me.
Depends on how far you are from your router and the construction of walls . You may need to get an extender which acts as a relay place it somewhere between the original router and the downstairs location. If it is a smart tv, follow the directions for the tv and make sure the adapter in the tv is compatible with your router. Check the specs.
SOURCE: Can't update the Wii.
Here is a link for your error code.This one looks very strange.I though I was offline and re-entered it lol.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=32022&system=Wii&locale=en_US&action2.x=19&action2.y=27
Good luck and game on!
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: I just signed up for netflix and am trying to hook
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
SOURCE: My Wii was connected to
1. Attempt to relink your Wii to your router from the wireless menu in the Wii.
2. If (1) above does not work, you can reset your router to factory settings then attempt connection again. BEFORE doing this, hook your Wii up to the router with an Ethernet cable to make sure you have a connection and not a problem with your wii.
3. If you decide to do a hard reset, go to the Cisco/Linksys website for complete reset instructions.
http://home.cisco.com/en-us/wireless?referrer=www.linksysbycisco.com
SOURCE: Netflix streaming worked until I connected my
hello... this problem is quite simple to fix... follow this step by step:
Power on your Wii
console and press the A Button on the Wii Remote to reach the Wii main menu.
Use the Wii Remote to select the "Wii" button. Now, select
"Wii Settings" to access the "Wii System Settings" menu. Using the arrow on
the right side of the screen, scroll to page two and select
"Internet." Select
"Connection 1: None" (Don't see
"None" in Connection 1? Click the Connection 1 button, then choose
"Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access
Point." (Are you using a
wired Internet connection to your Wii console? If so, click here for specific
help.) Select
"OK" and the Wii will display all the wireless networks it finds. Select the wireless
network that is yours. (If you're not sure
which is yours, or you don't see any wireless networks, click here.) Asked to enter a
security key? If you are prompted
to "Enter the Password or Key," then the wireless network you are
trying to connect to has wireless security turned on. You will need to type in
your security key or password and select "OK." Don't know your
router's security key? Let us help you find
your router's security key. Select the brand of your router below and we'll
provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple
2Wire All other brands Select
"OK," "Save Settings," and then "Yes." The Wii console will
run a connection test with your wireless network when the test is completed.
You should see the following screen: As long as you see
"The connection test was successful," the "Wii Support
Code" does not matter and can be ignored The connection test
was successful - Then you're almost done! After your connection test, the Wii
console will check if there is a new Wii System Update available. Once you
select "Yes" and "I Accept," the Wii will begin to download
any available updates. Click here to find out what's next! The connection test
was not successful - If the test was not successful, you will receive an error
code. Error Code 51330 or
52130: This means the security code you entered into the Wii is not the same
one your router is set to. Look in your router's settings and try again. Please
refer to step seven (7) above for more information. All other error
codes: Try our error code troubleshooting where we have detailed information on
many common error codes. (You can ignore any "Wii Support Code" you
receive on a connection test.)
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
