I would disconnect the remote cables at the engine end ! then move the gear selector by hand and see if you can select f n r freely , same with the remote control lever and see which is the problem ! ive known the control lever internals to lock up or brake etc , split the box and view the movements and check for damage on the lever or the gearing ! gear box is basic selector which slides between f n r , check the cable has not snapped also !
Check the shift cable adjustment
SOURCE: it will not go into reverse
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: when i put my mercury 150 into gear it hits really
See if you can turn down the base idle some. Then check your gear lube, sometimes you can get an airpocket and the top end is dry. Last, if still not fixed, see if you can adjust the cables so that the throttle RPM changes after the gears do.
You want a little lag in the throttle so you don't take out a dock when coming onshore.
SOURCE: mercury outboard goes forward in reverse and vise
you probably solved the problem by now, but the linkage is reversible in the control console, pretty straight forward when you open it up..
