Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Mar 24, 2012
Mitsubishi WS55315 rear-projection has gone dark
8-yr old WS55315 has gone dark. This follows a couple of weeks of 'warning signs' when blank screen would appear for a minute when set was first turned on. Now menu briefly displays, but no screen. Audio seems fine. Repair shops are listed in our zip code. Question is: realistically, is it a good candidate for repair?
  • 1 more comment
  • Anonymous Mar 24, 2012
    I found the service manual online--here it has on page 21 how to get into the option menu and do the option reset:
    http://www.scribd.com/doc/69330766/Mitsu...
    Thanks again. I did a hard reset as you suggested. We're back in business!
    GREAT NEWS!
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Mar 24, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718685
Points
48227
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Testimonial: "Thank you, SD Tech. Very helpful. Can you hazard a guess as to what the problem might be?"
    in the option menu is the hard reset and either it will cure it or not.
    I have that information but it is filed in USA and I am in Canada for a few months--It needs to be tried but this is a very stable set--unlike plasma, dlp, and lcd.
Hi i have an error 21 on my ws55315 how do i fix it?
i believe that code21 on that model is vertical deflection shutdown. the repair would be very involved i suggest calling a serviceman.
My almost 10 yr old Mitsubishi HDTV intermitently has color flux
The Main issues with the Mitsubishi HDTVs that size are the projection bulbs in the rear. A large TV like the Mitsubishi can allow dust build up on the lamps and the mirror in the rear that projects the picture to the screen. An easy fix would be to clean off the dust off of the mirror and bulbs. You would need to go through a tough processto do this since the mirror can be quite heavy and is in an ackward place. The only other alternative would be the need to replace the projection lamps themselves which can cost any where fromm $150 - in some cases $300 a piece for the lamp itself. The Television is still a great set but can cost quite a bit right now to fix if the problem is with the Lamps. If you can afford the Lamp replacement if it is needed the set would last you another 10 years plus. If you wouldn't like to go through the hassle of repairing the set or finding a place to repair the set there are so many new sets out in the market that will give you an amazing picture and quality.
1helpful
Green blinking light under timer
I can almost guarantee that the circuit board(s) have bad capacitors on them. I repaired one last week that had 20 bad capacitors on 4 boards.
Fixed one the week before with 15 bad caps on two boards.
A repair shop may be able to replace the boards, but it may be expensive.
- I hope my diagnosis is wrong-
4helpful
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors. Repair shop estimates are $340-420.00 Can I replace the...
Yes you will need to replace both of the STK392-570 Convergence ICs and the two 5 amp pico fuses. You can get the parts at the following link and they provide instructions with pictures that show how to do the repair. Heres the link'
http://servicemanuals.vstore.ca/
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
Mitsubishi 50" (14 yr old tv) rear projection TV
Yes this is the same as the others the voltage regulator is gone on your tv, replace it and take a good look at the power supply and horizontal ckt look for some cold solder
good luck
[email protected]
8-9 yr old Mitsubishi tv
Good Day,
Go into the 'menu' then advance area to the audio and turn speakers on. You must have TV's orig remote. Or go to menu:
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357". Choose reset.
Good Luck, big IRISH.
1helpful
3answers
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
