Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
either you charger or your battery is bad, chaeck the charger to make sure that its putting out enough volts with a multimeter, then visually inspect the batteries for bulging
Neil, I do not have a solution, but however have the same exact problem. Son got an E300 for Christmas. My daughter also received an E200. The E200 works fine, but the E300 makes a clunking noise when the throttle is engaged. Also the E200 can make it easily up the drive way, but the larger and more powerful E300 can not. Any help with this would be greatly appreciated. Thanks, Ron - [email protected]
there is a TSB(technical service bulletin) available at your dealership for that. Im pretty sure thats the cv shafts making that noise. its very common.
Control module
