The refrigerator side is cool but not cold. What can I do?
Open the freezer door and move food so you can see the entire rear inside panel. Do you see frost building up on this panel? If so, you have a defrost problem and your unit needs attention. It will only get worse. Supply the last few letters of the model number if you need further assistance.
Waiting to hear from you,Eric and Ann Campion
http://www.affordableappliance.com
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
SOURCE: The refrigerator is running but not cooling
I did check the fan and it was not operating and checked the voltage to the thermostat it was good and replaced the stat. It is working now.
Thank you
Todd
SOURCE: Our side by side refrigerator is not cooling. The
the coil freezes up solid. i take the inner liner out and take a heat gun to the coil, speed defrost and reassemble. 6 screws max.
SOURCE: refrigerator and freezer not getting cold side by side
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
SOURCE: Refrigerator side doesn't feel cool but the
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
heatman101
heatman101
heatman101
