Polycom VSX 7000 Video Conference Logo
Posted on Mar 19, 2017
Polycom VSX 7000 Encryption Problem
I have a VSX 7000S that has been working fine for a long time. I recently noticed that when connecting VTC calls via IP or ISDN, the AES encryption does not lock.
It did before, but seems to have stopped working. It is enabled under the security features. I also swapped it with a spare unit of the exact same model and settings and got the same issue...no encryption, even though it is enabled.
I'm communicating with other VTCs in the same company and AES is enabled as policy.
I have no encryption issues with other models. I'm using the same subwoofer that comes with the VSX7000. I know it serves as power, audio, and ISDN interface. Does it carry encryption??
It is common to both 7000s. I don't have a spare subwoofer.
3 Related Answers
Anonymous
  • 10 Answers
  • Posted on Apr 02, 2009
SOURCE: Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Anonymous
  • Posted on Jan 14, 2010
SOURCE: polycom VSX7000 video camera
Hi there:
This happened to my VSX camera and the fix was simple. I have a VSX 8000 so if your camera is different then mine you might not be able to follow this. This might not work for you but, try it. On the back of the camera you'll find a small little screw. Keep the system on and watch your cameras image. Start to loosen the screw. You'll only have to do it a little bit and the camera should start to focus again. Tighten the screw up (maybe not as tight as it was before) and test to see if it's auto focusing. Also....manually moving the camera around while it was on could have helped as well. Finally....I did not have to do this but if it is not working simply by loosening the screw...I would take it all the way out and remove the little cover or hatch that it holds. Poke around in there a little bit to see if the the focus motor unsticks itself. If you are still under warranty (I was not) don't do this...call the vendor who sold it to you.
Mine's working great now simply by loosening this little screw and tightening it back up.
Anonymous
  • 6 Answers
  • Posted on Jan 25, 2011
SOURCE: Polycom VSX7000, do you have to suscribe to
No, you do not need to subscribe. Are you sure your a/v cables are connected properly? You might also check on your video source and make sure you are in the correct source.
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Connects to far sites but there is no image, only a black screen. near site image is fine.
When i connect the other end successfully(all the blue balls color turned to green)but with only a sentence, says:"secure conference encryption 。。。"
Polycom VSX 7000 will not turn on
Hopefully the problem was resolved. Call Polycom to see if it under warranty. Call me at 415.659-8178 if it is not. Maybe I can help. David
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
11helpful
4answers
Forgot the polycom VSX 7000 password - how to reset
The polycom didn't allow for numbers, only letters.....
How do I do password recovery in this case?
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
