Hi so i have a hp pavilion a6030.uk and its been working fine etc and even yesterday it was working normal but for some reason when i opened my computer this morning was about to write an essay or type something, once i pressed the spacebar it makes a beeping noise, then my monitor goes to sleep and then i either wake it up with the mouse or one of they keyboard shortcuts to make it awake and it works but its everything the spacebar is pressed or used it does what ive said above. please can anyone help me solve/fix this issue...i think its the keyboard or something. im using a frends laptop to type this. please help, thanks
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
SOURCE: Slow or none response time for HP Wireless Keyboard
You might want to check the batteries being wireless, also check the device conected to your tower that reads the keyboard, make sure its pushed in all the way or not being disturbed by any objects.
SOURCE: Hello. My cat stepped on a keyboard after that I
If the keys are jambed and you cannot free them then you most likely need to replace the keyboard.
Replacement keyboard is available from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
check what people have kindly posted below and the keys arent jammed they are working fine apart from the stupid space bar and its not a wireless keyboard either :s but ive checked already to where it plugged in to connect to the comp etc and it seems fine...i dont know why the stupid spacebar is doing this
