Question about SanDisk Sansa c240 MP3 Player
My sansa device does not recognise songs in it
It occupying space of songs but when i select play all it shows no songs
  • SanDisk Master
  • 32,281 Answers
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Posted on Mar 24, 2012
SOURCE:
  • 6 Answers
SOURCE: Computer does not show MP3 player as connected and how to stop a song playing
If you installed the firmware update, you might have forgotten to change the device to MSC mode.. try going to settings>USB mode>MSC This should probably work.. to stop a song while its playing, click the |<< button while you have the screen with the current song. (you can pause a song on this same screen with the >|| button) If you have gone back to any of the menu screens, wait for a couple seconds and the player will automatically go back tot he song display screen so you can stop the song.
Posted on Dec 26, 2006
SOURCE: [Sansa e250] Deleted songs and now...
Go to the System folder and delete PP5000.DAT. This is the database. The player will then rebuild the database without the deleted files.
Posted on Jan 15, 2007
mixmaster
  • 626 Answers
SOURCE: music files won't show up
Is your device almost full? The player needs sever MB's of space to create the database or menu, for you to navigate with. Try deleting some music, then restart the device. Best of Luck.
Posted on Oct 06, 2007
  • 155 Answers
SOURCE: sansa e250 using micro sd card
change the mode of the player to MSC and connected the player to the computer, this will help detect the microsd as a removable disc drive.Transferring songs to the card is via drag and drop or copy and paste.
Posted on Dec 08, 2007
  • 4 Answers
SOURCE: Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Posted on Feb 13, 2008
I am not able to see the songs when I upload my MP3 with the computer, and it's occupying nearly 560MB space
Please use the software required to upload the files as the sansa will not recognise the normal mode music files unless they are compresssed to the requirement of the ipod.
Go to the link below to download and convert the music files and send them to your sansa.
www.5starshare.com/hottag/​sandisk-sansa-ipod.html
Sep 02, 2010 | SanDisk Sansa m240 MP3 Player
Cant delete music
Connect your sansa to the computer and then explore the drive and delete . also empty the recycle bin not to occupy space from your computer storage.
melnavz
Jan 23, 2009 | SanDisk Sansa m230 MP3 Player
Sansa c240 MP3 Player 1GB froze
Attention: resetting the device will delete all the songs..
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
May 23, 2008 | SanDisk Sansa c240 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Mp3 wont play downloaded music
The device has 2 modes on it MSC and MTP, if you changed modes and uploaded songs in the other mode, they are only visible on the PC in that mode. But, the PC will show the total amount of free space on the device.
If this is not the issue, I would try formatting your device to remove everything and start over.
You can FORMAT thru My Computer>Device Name (e280)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
You can also add to this question for additional support.
Nov 22, 2007 | SanDisk Sansa E280 MP3 Player
Music files won't show up
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
I dont kno what happened
You need to remove some music from the device. It needs at least 6mb to create the database. You can either format the device to remover everything. My Computer, right click on the device and select format. Or, open the device and manually remove a few songs. Restart the device and see if the issue is resolved. If not, you can call Technical Support and they can assist you. 1-866-726-3475 Best of Luck.
Sep 04, 2007 | SanDisk Sansa e250 MP3 Player
Will not recognise songs on player
Your Sansa E250 player comes in two modes -- MTP (Music Transfer Protocol) and MSC (Mass Storage Class). When you save songs on one of these modes, they would not be recognized by the other mode and vice versa. The reason for that is because the MTP mode is used for subscription music while the MSC mode is generally to allow your MP3 player to functions as a "Flash Drive", a regular mass storage device. To test if this is what's actually happening to your player, try each mode and see if you'll be able to "view" the songs when plugged in your computer: 1. Go to the modes on your E250 by navigating the player: Menu > Settings > USB Mode 2. When you've selected a mode, browse the player in your "Windows Explorer". Note: MTP mode will give you an icon of the E250 (player will be recognized as a Portable Audio Device) while MSC mode will have a Drive Letter (player will be recognized as a "Removable Drive") 3. Make sure that your Windows Explorer is configured to "Show all Hidden Files and Folders". To do this, access your Explorer's menu: Tools > Folder Options > "View" tab > enable "Show Hidden Files and Folders" You should be able to find the music files (or picture/video files for that matter) that have been taking up 1.4GB If you'd like to free up this 1.4GB, you may want to Format the player under MSC mode. To do that, right-click on the Drive Letter corresponding to your E250 in Windows Explorer, then select "Format". Follow the on-screen prompts and that should reset your player back to its original free space. Let me know if this helps. I may be able to offer some more solutions based on the result of the procedures above. Let's keep your Sansa E250 playin' :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
When you delete files on the sandisk it just moves them to an invisable folder labeled .trash inorder to free up some space you need to delete the files inside this invisable folder. if you are using windows then plug in the device and open it. go into you folder options and make sure it has show hidden files selected. If you are using a linux os then go into your view menu and select show hidden files. this should make the .trash folder appear. hope this helps.
Jan 26, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
