My friend has just sent me a bunch of audio files in m4a format and I need to convert them to mp3 as my media player doesn't support this format. Which software to use?
M4A is a kind of Advanced Audio Coding (AAC). It was developed by Fraunhofer IIS, Dolby LABS, AT&T, Sony and others to replace the MP3 format. AAC audio algorithm in the compression ability is far more than MP3, it supports up to 48 audio tracks, 15 low-frequency audio tracks, more variety of sampling rate and bit rate, a variety of languages compatible ability, higher decoding efficiency. Overall, AAC can provide better sound quality at 30% less than MP3 files.
So, if you want to convert M4A to MP3, there is surely some quality loss in audio. In order to maximize the quality of the audio source, you need a professional M4A to MP3 converters, and here are some recommendation.
I use this m4a to mp3 converter for the same purpose, it does all the work in a blink, try it, I am sure you will like it. And, by the way, it's free!
SOURCE: Sansa Media Converter will not convert MP3
Duh!
I went back and re-read the manual (phamplet) I downloaded the MP3 files directly into the e200. Works great now.
Like I said. DUH
SOURCE: The converted videos using media converter for
Hey!
You can have a try of this Wondershare Video Converter by which you can convert video to almost any video format for your players or cell phones including your philip. You can free download it at:http://www.dvd-ripper-copy.com/video-converter-platinum.html#181.
Hope that helps
SOURCE: NEED TO USE THE PHILIPS MEDIA CONVERTER
All support for the SA6045/02 is on this page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/02&slg=en&scy=GB
Scroll down to Software and drivers to see the Media Converter software.
Click the zip file and best would be to save the file to a location on your computer.
After the download finished, unzip the file with WinZip or Winrar.
Open the folders of the extracted files:
under folder
MC_2.0.2.80_SA33xx_SA61xx_Intl_GM_CD02004_0928 start Setup.exe to install Media Converter Software, ArcSoft.
MediaConverter for Philips converts following formats to player, into WMV :
AVI (Microsoft video I format), MPEG-1, 2, 4, DVD (*.vob), MOV, WMV, RM etc.
Needs Quicktime (for MOV) and Windows Media Player 11 (for WMV)
installations.
SA6045/02 manual:
http://download.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
SOURCE: RE: GPX Touchscreen Media Player
you will need an advanced movie editor or converter that can convert the video from the supported types(even if it is already an .avi file) to: 320x240 resolution, using the xvid mpeg4 codec for video and mpeg layer3 mp3 audio codec. the quality can only be as high as 64 kbps i believe.
the player itself comes with a converter either built-in or on a cd. this converter sucks though and wont sync up the audio to the video very well at all. so i suggest you use a high quality converter so the videos will be watchable.
