How to set the time on an HD 1688 Quartz wall clock
I need to know how to do a manual set so i can set the clock to the exact time i want. It keeps going around and setting to its own time. I am on NY EST
    New Friend:
When you put in a new battery, the hands advance to the hour and stop. It then waits to receive a radio signal and sets the time.
to do a manual set, insert the battery and hold down the M button until the correct time. Don't go past it or you will need to continue until it comes up again. There is no reverse.
The previous answers don't fit the HD-1688 Sheng Bang clock mechanism that I have.
Posted on Jan 10, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
On the Sheng Bang HD-1688 make sure you remove the locking pin from the back. It keeps the gears from moving while in shipment. Insert a new battery. Set the timezone switch to Pacific, Mountain, Central, or Eastern. Set the daylight savings switch to "On" unless you're in a state that doesn't observe it (Arizona, Hawaii...) The second hand will sweep to the 12:00 position and the hour hand to the 4:00 position, and the minute hand to the 12:00 position (I think. It may sweep to the 4:00 position too. The instructions aren't clear on this point). Place the hour, minute and second hands onto the clock shaft in that configuration. Press the "REC" button for five seconds to force the mechanism to seek a radio signal. Make sure you're near a window for best reception. It may take an hour or more for the clock to find a good signal. This works best at night.
Here's the location of the full manual:
https://content.etilize.com/User-Manual/1014567573.pdf
Posted on Jan 23, 2019
5 Suggested Answers
SOURCE:
SOURCE: Manual Information/Owner Guide
So where do I get the manual?
Posted on Jun 18, 2008
MNfisherman
  • 11896 Answers
SOURCE: Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Posted on Jul 06, 2009
sg1972
  • 225 Answers
SOURCE: Set the clock to DST
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
Posted on Mar 26, 2008
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Posted on Mar 14, 2010
I set the clock for a morining time, but it goes off in the evening.
There should be some kind of indication whether you are setting time in AM or PM. You may have missed this as you rotated through the time setting
Dec 17, 2012 | MZB Imagination SpongeBob SquarePants...
The clock keeps counting down and it stops. the store where I bought it has closed and/or moved from my area. please help me with an address/phone and solution.
you need to change the settings on the treadmill. you probably have it set to stay on and work for a set period of time. try going through the settings menu. if you need additional help, consult the manual. should be available online. if you gave me the exact make and model of the treadmill, i may be able to find a downloadable version for you
Aug 12, 2011 | Exercise & Fitness
The clock stopped, I replaced the battery but it does nor reset itself it keeps going
Hello
This is the setting proceedings for you Atomic clock. Follow this.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Jul 09, 2011 | La Crosse Radio Controlled Atomic Clock
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
How to change time of day on WM336 CD player
Turn off radio and hold mode button to see if you can set clock that way. I know you have to do that on some older radios like pioneer and sony. If you give me the Xtreme web site you have I will try to help you more.
Good Luck
Feb 27, 2009 | Xtreme Sound WMS336 CD Player
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
How to set time
http://www.emersonradio.com/owners Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
May 09, 2008 | Emerson Smartset Clock Radio
Cant set time
Rondart
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory5.gif.
Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
The third is just the brightness.
Now, to set the time itself:
1 - Turn the clock face back up to where you can see it.
2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
Good Luck!
Mar 10, 2008 | RCA RP5420 Clock Radio
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
32,200 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
