There are no instructions for changing the belt on my eureka vacum 437za i called eureka and they told me to take it to a service center unsat answer
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
SOURCE: belt change for eureka capture
There 2 or 3 screw on the top cover to remove, then it comes off. Then you can get to the belt, inspect the brush roll while you have it out, make sure the ends move freely.
SOURCE: How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, [email protected]
SOURCE: MY VACUUM ISN'T PULLING AS STRONG AS IT USED TO SO
i have never heard of any belts in a vacuum cleaner
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
