Question about Cameras
I have a hahnel unipal charger and the light is just flashing by itself with no battery in. when i put my battery in it wont charge. i need help
The light that flashes when i put the battery in, it isnt that light that is flashing.
    Master:
  • 577 Answers
Short in charger .
Posted on Mar 22, 2012
SOURCE:
walkietalkie
  • 32 Answers
SOURCE: battery wont charge flashing red
Every rechargeable battery deteriorates thoughout it's life of usage. may be it's time to buy a new one. Sometimes the terminals on the battery get in touch with metal things and short the circuits within.
Posted on Jul 12, 2008
SOURCE: problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
Posted on Dec 31, 2008
SOURCE: Battery charging
My mom and stepdad had the same problem less than one week after I bought it for them. I called Casio Technical Support, and they were awesome! They just needed the cradle number and the serial number to send them a new battery. I was on the phone less than 5 minutes.
Posted on Jan 04, 2009
vortash
  • 431 Answers
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
Posted on May 29, 2009
Rammsteins
  • 300 Answers
SOURCE: when trying to charge my battery... the light
Battery problem. Well known problem with the NP-20 battery. It can be repaired by connecting it to ~4-4.5V 1-1.5A for about 5-10 seconds and then charged normally with the charger.
Of course a new battery will be better.
Tom
Posted on Aug 02, 2009
DW911 charge light flashes when no there is no battery in radio
Sometimes when a battery is too low it takes a while for it to initialize in a charger and begin to charge. Clean the battery contacts with a pencil eraser and put it back on the charger. Leave it on the charger despite the blinking light. Leave it on the charger for several hours and see if the flash stops and it becomes a constant light indicating normal charging. If this does not work, you may have a short in the battery or in the charger itself. Try another known good battery in the charger and see if you have the same problem. If so the charger has an issue.
Best regards.
May 22, 2013 | Radio Communications
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Hi, I have a Hahnel combi TF that i am using as a wireless flash trigger (not the wireless shutter release). When i turn the camera on, the flash on (jessops 360 AFD on the manual setting) and then turn...
This worked for me: The coiled wire + battery contacts on the receiver unit are quite flat.I took a small forceps (needlenose pliers would work as well), and pulled the coil into the battery chamber so as to make a more assured contact.
Jul 20, 2011 | Cameras
Battery was low so put in charger.laptop then turned itself off.been on charge 3 hours,still wont come on.led lights flash 3 times when pressing on button
take the battery out unplug the charger hold down power button for 10 secs replug charger back in with out battery then see if it turns on
Feb 24, 2011 | Computers & Internet
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
The camera ran out of charge and now when i put it in the charger it wont switch on or charge up and the charge light is flashing intermittently. Thanks
I found this while trying to solve my very similar problem. It worked for me after about 7 times. Other people wrote that it wook them 20 times... good luck!
ylu1 writes:
what i did was...
hope this helps.
May 29, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Cameras Logo
745 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
