Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
right click on the speaker icon in the bottom taskbar select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps you W7
SOURCE: logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
SOURCE: Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
SOURCE: Logitech R-20 + Windows 7 = Subwoofer not working
First check and make sure that the speakers are securely connected.
Then open sound and audio devices, in control panel, and scroll down to speakers,.
click on advance and change the selection to surround. .
click apply and OK you may have to restart to get the effects.
SOURCE: Logitech R-20 subwoofer not working on windows 7
This undoubtably is a driver problem. You could try running and installing in Administrator, mode and compatability Mode for XP SP2. Either that or ask Logitech whats their fix.
SOURCE: I purchased a set of
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
