I just got a Nikon Coolpix S8100 and when I turn it on to take a picture it say Mode Dial is not in porper position... I can view pics but that's about it.
SOURCE: nikon coolpix S3- most of the screen is black on shooting mode
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
SOURCE: nikon coolpix camera has lines
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall. Contact Nikon support-this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
