1998 Isuzu Trooper Logo
Anonymous Posted on Mar 22, 2012
I cannot start my isuzu bighorn w/4jx1 engine. we already changed the turbo but still it emits too much smoke in the exhaust and after a while the engine goes wild and we cannot turn it off in the ign
Isuzu bighorn 4jx1 engine wont start accumulates oil i the impeller emits too much smoke in the exhaust
  • 4 more comments
  • Anonymous Mar 22, 2012
    engine goes wild after a while of starting the engine and the engine wont turn off in the ignition
  • Anonymous Mar 23, 2012
    it is a diesel fueled engine
  • Anonymous Mar 24, 2012
    accumulates oil in the turbo shaft and the impeller. causing the turbo to break. we already changed the turbo twice due to his problem. please help us.
  • Colin Stickland
    Colin Stickland Mar 24, 2012
    Have to think about this one but if excessive oil as you say then i think its time to pull the head off and grind the valves in and check the piston float on each piston at tdc as you may need a new set of rings as well ,new valve guide seals as well maybe even new valve springs as this sort of oil build up in the turbo has to be coming from somewhere and a worn engine is the only possibility .Not a lot else will cause this except worn bearings in the turbo but you have changed it twice already so it looks like a engine rebuild is on the cards
  • Colin Stickland
    Colin Stickland Mar 25, 2012
    rght i was tired last night ,too much work for an old man like me anyway check the engine breather where it comes into the inlet air filter and then see if its all oily and weither the cold air/hot air flap is open and not jammed closed as this would allow the intake to draw the air for the engine from the internal of the engine sucking in the oil ,have seen this in extreme case like a fordD series turbo truck some 40 yrs ago where someone had tried to start it with a lighted rag and it got sucked in the air filter
  • Anonymous Mar 26, 2012
    but we already tried to start the engine w/out the turbo and it wont start. tnx anyway. we will try what you've suggested... hope it will work. tnx again
Colin Stickland
Level 3:
  • Isuzu Master 22,516 Answers
  • Posted on Mar 23, 2012
Colin Stickland
Isuzu Master
Level 3:
Answers
22516
Questions
Helped
6998728
Points
66324
Its a diesel and its running away so do not try to start till you do the following and yes i know i will be amolished for being a cowboy by the other experts but what you do is to make a gasket for the EGR valve from a coca cola can and seal it off if you dont it may run away and blow itself to pieces .If you do this then it run as normal as the older trucks never had these thing fitted and they all run ok in my day ,exactly whats wron i couldnt tell you without my head under the bonnet but do as i say and it run perfectly
  • 3 more comments
  • Anonymous Mar 25, 2012
    tnx colin stickland. we'll try what you have suggested. may i ask you if the breather of the 4jx1 engine is on the top of the valve cover going through the air filter. we are from the philippines. and the mechanics here dont know what else to do. we already tried starting it w/out the air filter but it still accumulates oil in the turbo coming from the exhaust. the oil in it is mixed w/ diesel fuel.. tnx for your info.
  • Colin Stickland
    if the exhaust is filling with oil and diesel then i couldnt be sure as without seeing it my self its difficult to say ,if your geting oil and diesel up the exhaust and when you do det it to run its running away then you have a serious problem ,cannot say i can remember where all the parts are on this bighorn as only ever done one in all my life and that was a few years ago then only a service at that ,If you have oil in the ehhaust side of the turbo is their oil in the inlet side if no then its a problem with the engine and if yes then its the turbo ,what you could do is to disconnect the turbo and block off the oil feed pipe and try starting it then ,Now another thing to try is to remove the injectors and the rocker cover now make yourself a rubber tube that fits into the injector hole or a broom handle with a hole drilled down the middle then turn engine to no1 with both valves closed and blow compressed air down the home made adaptor and see if the air escapes either up the exhaust or inlet manifolds or the adjacent injector hole this will tell you if you have damage anywhere like a piston burnt or valves leaking or a head gasket ,which thinking about it ???? oil pressure feed to the valves the oil passes through a hole in the gasket to the top of the head in extreme cases i have seen the oil ending up in the nearest piston and be blown out without hydraulicing the piston .I know some of the other experts will no doubt amolish me for giving this compresed air advice and making your own adaptor as its not the done thing by a dealer mechanic but iam a old fleet fitter where the vehicle has to go to work at 07.00 am the folliowng morning .Now give it a rest for a day ,have a coffee and a ciggy then have another look
  • Hi Anthony, Sorry for sticking my nose in Colin. The 4JX1 is a common rail diesel injected engine. The injectors operate with electronic commands from the management system. The Oil Rail Pressure Sensor which is situated on the oil rail,(which is fitted inside the tappet cover and fitted over the injectors together with the high pressure fuel and oil delivery pump are the most likely places where fuel and engine oil mix. I suggest the replacement of the gasket washers as a first action of remedy The second area should be the high pressure pump which pumps both engine oil and fuel up to the fuel rail. As you've experienced acceleration run away, I suggest identifying and cutting the cable to crankshaft and cam shaft sensors. Once cut,, making sure they cannot cause a short circuit, strip a little insulation from the cables and join each together with a dry splice, so that either can be pulled apart in the event of a runaway. In that event the crank sensor is the one to choose. Regards John
  • zigmas
    zigmas May 19, 2014
    ISUZU TROOPER 3.0 4JX1 HIGH PRESSURE FUEL/OIL PUMP
3 Related Answers
badealer888
Stan Cather
  • 414 Answers
  • Posted on Jan 20, 2011
SOURCE: My Isuzu Bighorn 4JX1 RJM Engine stalled after
White smoke is usually a sign of coolant burning. Carefully open the coolant cap, sniff the inside. If there is an exhaust smell you more than likely have head gasket problems. A further diagnosis is needed to be sure. Also ensure that any wires/plugs are reconnected. If the oil sensor is unplugged the vehicle wont start.
simontricket
Simon
  • 235 Answers
  • Posted on Aug 25, 2009
SOURCE: Isuzu bighorn diesel 4jg2 engine timing diagram
http://www.jeepolog.com/UserFiles/downloads/trooper_manual.pdf
This site has it .
stevenhurc
Steve Hurc
  • 459 Answers
  • Posted on Jan 22, 2011
the engine oil pumps are in the rear of the engine(trans out) and behind flexplate /flywheel, were any of these 2 engine oil pumps touched if so the flywheel /flexplate has to be timed to crankshaft position, so you might have it in the wrong position, if your talking about the diesel lift pump (injector pump) that also supplies high pressure engine oil to injectors, after replacing this there is a learn procedure for the rail pressure control valve that is on pump. this can only be done by dealer or some one with Tech2 scanner tool.
Testimonial: "This was very helpfull and my car is now running. Thank you so much."
1helpful
I need diagram showing an isuzu wizard 1998 deisel 3 litter timing marks or degrees and valve clearance
I will talk about Isuzu Wizard eng.4JX1 turbo 3000/ Diesel, It takes time to Start and after get Started comes a White Smoke from the exhaust and also the is a miss firing. I can also see there is Eng.Oil coming from the throught Body direct to the Turbo but not so much but is visible when the engine is tuning and the car this not have power now. What can be the problem, what must be fixed???
We live in New Zealand and own a 1998 Isuzu Bighorn, 3.0D. About 3 months ago it started idling roughly and stalling just after starting. Then it stalled on me when I was driving 70kph. It also has no
wow first post ever posting country ,what a brave person. !!!!
welcome to USA forums ,that have no such car.(truck)
the line up. (wiki list) so its 3.0L 4JX1
stalls and lost power.
The 4JX1 is a 3.0L direct injection diesel engine, turbo, some intercooled, which replaced the 4JG2 in the Isuzu Bighorn/Trooper/Holden Jackaroo. It uses unit injectors and 4 valves per cylinder.
can be caused by many reasons. get it scanned yet. ?
or see FSM book on flash codes from the direct injection fuel
controller? (per this engine option and market)
does turbo have proper boost? (PSI boost or +1 bar boost?)
does it even have a boost gauge.?
there are over 50 causes, of stalls (most inside engine)
but its not getting boost or the injection rates are wrong.
there are basic tests for each covered in the FSM
Factory (oem) service manual, with coverage for this engine.
3.2 L 6VD1 SOHC V6
3.2 L 6VD1 DOHC V6
3.5 L 6VE1 DOHC V6
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4
2answers
DIESEL FUEL MIXING WITH WATER IN THE RADIATOR
Get some BLUE DEVIL and follow the Directions. You have a Blown head Gasket or a Cracked Intake or Head.
I have got a 4jx1 Holden Monterey 2000,and I have just changed the turbo,cause the other turbo blew last week,and since the change,the truck is smoking when you start it up,and when I get to a 100ks it...
it could have engine dammage or just that the exhaust is full of engine oil from old turbo blowing up and its burning off
is the engine oil going down? if so motor damage
1helpful
My Isuzu Bighorn 4JX1 RJM Engine stalled after fitting it with new oil pump. It can crank but is emits smoke but not run. What could be the problem? I have tried to check if the fuel pump is not working...
My Isuzu Bighorn 4JX1 RJM Engine stalled after fitting it with new oil pump. It can crank but is emiting white smoke. What could be the problem? I have tried to check if the fuel pump is not working but...
20helpful
2answers
Isuzu tropper 4jx1
You have no injection pump ,each injector does that job .
You have a faulty rail oil pressure sensor I think ,read my tips to test this sensor .
10helpful
3answers
How to test the high pressure oil pump?
If you have no oil pressure on the dash gauge you need to drop the tin sump under the engine and check the two oil pick up pipes in there . They crack and fall off or the seal goes hard letting in air so no oil pumps. An known fault on the 3.0
The long one is for the engine oil lube ( turbo ) and the short one is for the injection system .
The high pressure pump is only for the injectors.
If you have good oil pressure on the dash gauge then I agree with Guru Ronaldbrains the turbos are poor but ! its 5/30 oil in 3.0 4JX1 engine or you will have starting troubles .
33helpful
4answers
Isuzu 4JX1 EngineWont Start after replacing new injector
my isuzu bighorn will not start after changing valve seals and head gasket and after setting timing it still will not start. do you have a solution.
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
