Televison & Video Logo
Kris Brand Posted on Oct 12, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi Cs-35707 Tube
Here are some pictures of the 4x4 board
Anonymous
Level 2:
Sergeant:
  • Expert 337 Answers
  • Posted on Oct 13, 2006
Anonymous
Expert
Level 2:
Sergeant:
Answers
337
Questions
Helped
152147
Points
699
I am sorry,in my other response I had this tv mixed with a rear projection tv,the response still applies because one of the transistor in the standing metal plates being held by escrew is the green output transistor and I can see it has 3 of them(one for each color)Look up the number on its face and replace it with an exact replacement or replace all 3 at the same time,it will not cost much.Let Us know how it goes.
When we turn the tv on the picture has lines i hit the back of it and the picture comes in
after 4 or 5 yrs ( depending on usage ) in some TVs on mainboard & crt tube's circuit board at few soldering joints cracks develops ...... then due to loose connection TV behaves as you said ..... so solution is most of the soldering joints on mainboard & crt tube's circuit board should be resoldered carefully ....that'all your TV will again works normally ......100% GUARANTEE
I have a tv mitsubishi model cs 27205 the problem is green screen, what is the problem?
CHECK RESISTORS ON CRT BOARD .THE BOARD IS MOUNTED AT THE BACK OF PICTURE TUBE .
Picture is rolling
few capacitors in vertical output leaking.just replaced...
2answers
Shuts down after a time
high voltage transistor cost to repair or regulator, 100.00 to 150.00
3helpful
3answers
Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
TV lacks green, but has prominant red/pink 3
Excellent pictures of the crt board I can actually see the transistor ans is mounted in a piece of metal with a screw holding it,is just to the right and he should be the only one of this kind in the board,this transistor is soldered in and it needs to be replaced with same,in its face it has some number ,the part can be ordered or cross to a replacement with those numbers.Make sure all the conections on the board are solid.Let us Know how it goes.
TV lacks green, but has prominant red/pink (Question 2)
Those are magnets and not outputs ,the outputs you might be looking for are in the crt board and is an actual transistor,do not move the magnets and try to realign to the way they were,the crt board is at the end of the neck of the tube and it can be remove very carefully,do not twist this board or the picture tube might break and then we are in trouble.Take a picture of the board it should be about a 4"x4" in size.Make sure the set is not plug in when you work around this parts.Lets Us know when you need more information.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
