Powerware 9120 Hi, i have a Powerware 9120 3KVa here, it switches on and gives me a 'Charger Failure' on the display panel. Do i need to exchange the board or is there a solution to this? Regards Stephen
  • Stephen39 Nov 06, 2008
    New batteries, same problem.
    New batteries same problem.
  • 189 Answers
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Posted on Nov 06, 2008
  • erwinroyo
    erwinroyo Nov 06, 2008
    If you have a new battery replace, and yet still the problem occur. There is a defect on the board circuit, have the technician look for it, or replacement is needed.
    Thanks.
SOURCE:
Bc bus fault of 9120 2KVA
Suspect charger board failure. Replace with new model 9130. 9120 is obselete
Mar 21, 2013 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | Powerware 9120 UPS System
UPS 9120
did u check the fuse inside the ups?
did the ups gave the error right after u replace the batteries? or some time after.
sometimes gives the message some time after and its because the charger isn´t working properly. the charger is a spare board in the 9120, 5 and 6 KVa.
good luck
Jun 21, 2008 | Powerware 9120 UPS System
Computers & Internet Logo
475 people viewed this question
Alun Cox
