SOURCE: fractional powers
use the "carrot" button, ^. Type in 4^.5 and you get 2. If you are going to use fractions, use the division bar and parenthesis and not the fraction key. Example 4^(1/2) = 2
SOURCE: I need to find the antilog to -6.80 on a casioi fx-300ms calculat
Alot of people have this doubt, so I might as well make it clear.
Press the 10^x button (while pressing SHIFT, of course; it's exactly above the LOG button) followed by the number whose antilog you desire.
Example :
Let's say we need antilog(-6.8),
1. Press SHIFT, followed by LOG (i.e 10^x); this'll display a 10 on the screen;
2. Type in -6.8;
3. Press "=";
4. This'll display 1.584893192x10^-7 as the solution, which is correct!
5. Bye, lol :P
SOURCE: fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
SOURCE: How do I divide fractions with the fx-300ms?
Look for button like [ a b/c ] it's the fraction first enter the whole number then press the button then the upper then the button and the down part, if you need only b/c so enter b press the button then enter c.
Rate me, thanks.
SOURCE: Dividing fractions
Once a fraction is entered it can be submitted to all allowable operations, like any other number. So keep the fractions coming. The calculator will reduce them to their simplest expressions.
Hope it helps.
