Bought last model, the shelf one, looks great and brews but it won't let me set the clock...i push the hour button but nothing happens, also won't let me set the delay. I got a good deal, but really wanted the delay feature. I don't care about the clock, it is working from it's original 12:00 and I thought I could just calculate the time and use the delay that way but the hour and minute buttons don't do anything at all
SOURCE: Mr. Coffee TFTX85 Coffee Maker
I despise the TFTX85!!! It will overflow, it will stop working! It will never tell you the correct time! It is evil in a coffeemaker. Check out our problems with this piece of junk at pisymphony.com ( opinions)
SOURCE: clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
SOURCE: model ftx26-1 stopped half way
Sounds like there is no power to the unit. Are you 100% sure the receptacle it is plugged into is working? If it is in a kitchen it may very well be plugged into a receptacle that is protected by a GFIC. Look and make sure one has not tripped. If you find out that the receptacle is good and power is reaching the unit, then it may have an internal fuse. It is highly unlikely the heating element and clock went bad at the same time.
Testimonial: "he hit is on the head. I took the coffee maker apart and the heating element is open. I will replace it or buy a new coffee maker "
SOURCE: Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
