SOURCE: he difference between Harley davidson road king frame and a soft tail frame
I put on street glide shocks on my 2007 Ultra. My wife and I rode 2 up with lots of extras. We had no problem cornering or handling of any sort. I moved the same shocks to our new 2009 FLHR with the same result. I am 5'9" tall with a 39" inseam and sit this bike well.
SOURCE: oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
SOURCE: 2001 harley davidson fat boy fork seals leak
Either the seals were not installed correctly or your tubes and sliders are excessively worn. Not changing the fork oil at recommended intervals will cause excessive wear. Overfilling the forks will cause leaks too.
