I just got a software to download video which can download videos .
i am not sure whether it can help you.
And the link for the FREE youtube Downloader for you.
SOURCE: I want to flash my
when i want listen the music through music plyer or gallery from my nokia 5220 XPRESS MUSIC it is showing that NOT ENOUGH MEMORY.How toget solved from this problem?
SOURCE: why my nokia 5220 xpressmusic doesn,t support sis
Hi there..!
Nokia 5220 xpressmusic is a Phone based on S40 symbian platform.
.sis and .sisx files can only be installed on phones based on S60 symbian platform.
.MP4 video format is another option with enhanced clarity when compared to .3GP video format.
SOURCE: Hi, I have nokia 5220, its now giving error
hi,
5220 is a baseband 5 unit of nokia ,an express music phone...since its so many function like music player,video etc,its software is very sensitive...that trouble cannot fix by any reset code ,formatting ,hard reset or factory setting...you need to go to a nokia care center or expert mobile technician to reprogram your cellphone by an appropriate software because that phone cannot be DOWNGRADED ...thanks for trusting fixya ,i hope it will help you..
SOURCE: I cannot install and remove
Your phone has been infected with virus.I also had the same problem.Please enter *#7370# on your phone and restore settings and your problem is solved.Please don't forget to rate me as ' helpful ' if satisfied.
SOURCE: My nokia 5800 xpress music's
Reset your mobile to Factory Default Settings
To reset your mobile type this code on mobile screen:
*#7370#
If it doesnt work type this code it will work:
*#7780#
You can choose the file from here .Open http://www.blue-nokia.com/index02.html and in the left
side of the window there you will notice BB5 SUPPORT click there
and you will again see various models of Nokia Mobile Handsets.Then, make a
selection to 5220.Again there you'll see different download links.choose the
last one by clicking to the download link you will lead a new windows.I think
this is enough.......you can when you get there.Thanks
. thanks for visiting fixya. Good
luck.
First download and install
Pheonix from this link. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link 5220 file and install it to C / program
files/pheonix.. after finished this installation open pheonix . Inside the
interface at the> top left
<there you see "File" click there and choose "open
file" and then select the approprait Product type i.e
"which is written on the back panel inside the battery of every Nokia(Type
RM-000).After doing this again at the left top count from
"File"1..2..3..the 4th one is "Flashing" press there,
when you click there you'll see three sub-menus, just select the "Firmware
Update" again you'll see another interface. Look at the product code
there should be blank and put your "mouse tool" at the straight end
from the "Product Code" there is a Button and
choose the code which is written in the back side of your phone. e.g CODE:0000000.if
the same code does not found just take one which is higher. After this you can
see "Dead phone USB flashing" click that box. Now this is the
last stage... Connect your phone with the USB to your PC and let
the driver install ...wait for a moment.(If
your phone working).Lastly after just finished (In case your
phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
button after this, a message will prompt you "press power botton"
etc. insert charger or press it and wait
until the phone will Restart automatically in normal mode 10-15 minutes. If you
cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good
luck.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5220 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5220 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file 0r 5220 file and install it to C / programme files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
I'm giving info about the product....
please solve it yourself...
If you are successful please tell me the solution, because I myself don't know.
Productcode-0563406(RM-411) version- 06.51
http://forum.gsmhosting.com/vbb/f421/5220-xpress-music-rm-411-flashfile-needed-568708/
http://forum.gsmhosting.com/vbb/archive/t-756742.html
