I have a SC-DC163 camcorder and when I tried to transfer the videos to my pc, after following all of the directions, it does not respond when I press the Menu button. Also, I need it to be transferred from the disc not a memory card like the directions state, but either way nothing works. I've tried finding answers to this or troubleshooting guides but this is not covered anywhere. Also, is it possible to transfer from the disc to a memory card on the camcorder itself?
Thank you in advance.
The way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
thank you for using fixya
CHARCOIS
i will give you a step by step on your camcorder.connect your camcorder using your USB cable to your computer and be sure it is ON
Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
burn your videos on NERO software
Hope you understand my procedures. Good Luck!
CHARCOIS
a rate of my suggestion will do. thanks for rating me!
CHARCOIS
I had to order the USB cable and the program because it was missing when the camcorder was given to me, when I ordered the program the booklet that came with it was very unhelpful so I don't know how to just save the videos to my computer. I think I've already downloaded the drivers, if that's what it prompted me to do when I installed the program. Is there supposed to be a screen that pops up when I connect the USB cable to the camcorder? Because all my other cameras and equipment have that, but this does nothing when I connect the camcorder to the cable and turn it on, besides say that it is connected. Sadly the videos are on a disc and not a memory card. So I guess I need a way around that direction to upload the videos.
I think it is working, I tried it on windows movie maker, it's capturing the video now. So I'm thinking that's a safe bet that it's finally transferring to my pc. Thank you so much for your help, you're amazing! I've been stressing over this for several days trying to figure it out, I don't think I can thank you enough :)
