Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
Aloha, ukeboy57
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
Firstly I would run a descaling solution through the tank and then make a few pots of coffee without using any coffee grounds. This will flush the sytem through.
The machine is always on, so it is never full the first time you use it on monday. Try this before you use it on monday pour in a full pot of water in the brewer and put an empty pot under the head. Wait about 7 minutes, the machine will fill the tank and then be ready for brewing coffee.
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
You should keep the unit full of water all the time it's plugged in, as if it is low on water, the heating element will burn out. A Bunn VPS brewer holds about 2 -64 oz pots of water in it's resevoir.
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Thanks! I will try it tomorrow and let you know if it worked.
CSS
