I have A Toshiba XP1 data projector That Has Hundreds Of Tiny Very Bright White Dots On The Display... I Read Somewhere That If It Were Dust, There'd Be Shadows... I See No Shadows... I Still Have Color, So Do Not Believe The Color Wheel Has Anything To Do With It... Could It Be A bad Chip On The DMD Board?
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
SOURCE: replaced bulb-now very bright white display
go to menu and to screen and adjust brightness and contrast
SOURCE: i have a tdp xp1 , toshiba projector and are
Dear all
if pixel is dead you have to replace penal or complete Engine
Thanks
Mahesh
Mumbai -
SOURCE: My Toshiba XP1 Projector is
Check the lamp indicator LED on the top of the projector for a possible fault condition. You may just need a new lamp.
I too have the problem but black dots. I have cleaned the lense with lotion and cloth and is clean. The output however is the same. Please help me with solution
