When i power on unit it ask hdd password unable to go in bios and boot menu .its first ask hdd password .
You can ask the real owner that put the password lock on the hard drive for it. Otherwise, it's a useless laptop to you. 99% of the laptops that have a password on the hard drive where the current owner does not know the password either stole the laptop or purchased it hot off the streets. The real owner put the password on the drive so that if the laptop is stolen the thieves cannot get to sensitive data.
SOURCE: How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
u have to do this remove your BIOS battery from the motherboard for few mints then put it back your problem will solves
SOURCE: HDD master password
inter the name and model in google with some thing like hdd master pass word. look for forums have you tryed your oem site?
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: lenovo bios password
I found a homepage with a load of Backdoor passwords, - one of them will bypass you forgotten BIOS password. If you dont know your type, you´ll have to try them all out, or untill you hit the right one:
http://www.computerhope.com/issues/ch000451.htm
Good Luck
/Teis -> dont forget to vote before you leave :-)
SOURCE: Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode
now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now
you will come to old screen and previously configured desktop with all
intact aplication and icons on desktop and it will no more ask you for
password till you set a new one
Thanks and regards
Kindly rate this solution
SOURCE: Aspire one d255d new machine i
press del or f2 to go into your bios
you will find the settings for the HDD password in there
