Armitron All Sport Digital watch Logo
A
Anonymous Posted on Mar 20, 2012
Armitron all sport #40/81475v due to leap year i cant get day and date to match
When leap year hit this year it made the days and dates not match what can i do
2 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: need instructions for setting armitron 40/6735
This should help with the 4 buttons:
Push the button Lower left and hold it for 2 seconds and you will see a number flash. This is for the alarm setting.
Push the same button again and a new screen with the time comes up and the seconds are flashing.
Push the top right button again and the minutes will be flashing.
Push the top right again and the hours will be flashing
Push the lower right one time and the time moves ahead 1 hour
Push the lower right again for the next hour and the time moves again. Do this as many times as you want to change the hours. Each time you reach 12:00 the screen will change the “A” and “P” to tell you if you are in AM or PM. Time.
You can set the minutes in the same way as you do the hours by pushing the lower right (set) button. The when done push the lower left to stop the set-up
After you set the time or the alarm, push the lower left button again to stop the set-up.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Aug 05, 2010
SOURCE: I have not been able
You will find link to all ARMITRON watch manuals in my tips.
2answers
Need to to set date and day on my Armitron 20/4591TT watch.
To set the date and day on your Armitron 20/4591TT watch, follow these steps:
  1. Press and hold the mode button until the display starts flashing.
  2. Use the hour and minute buttons to set the current time.
  3. Press and release the mode button to move to the date setting.
  4. Use the hour and minute buttons to set the current date.
  5. Press and release the mode button to move to the day setting.
  6. Use the hour and minute buttons to set the current day of the week.
  7. Press and release the mode button to exit the setting mode.
If you are having difficulty setting the date and day on your watch, you may want to consult the owner's manual for additional instructions.
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
3helpful
How do i set the time on a armitron 45/6975 watch i lost instructions
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards, VOTIT
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
I cant figure out how to set the time and date on an armitron mens M516 all sport 40/6753
I cant figure out how to set the time and date on the armitron instalite
3helpful
3answers
I can't find the user's manual for this watch: Armitron Sport 40/8125BLK Watch
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
2helpful
Unable to set day/date/year &time
Follow this link and download instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
1helpful
2answers
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... [email protected] (Mar 14, 2010)
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
