Question about Sony VPL-ES7 LCD Projector
Sony VPL-EX7 projector fan is broken. How do I fix/replace it?
Fan does not work. How to repair or replace it?
5 Suggested Answers
6ya staff
SOURCE:
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Posted on Mar 26, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Anonymous
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I got flikkring picture display with my sony vplex7 projetor
Try a different source ie a laptop and see what happens.This sounds like a source problem.
May 03, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Blinking power on switch 4 times what is the error message related to. took the lamp out of this machine and put in another worked fine...any ideas...thanks
PROBLEM: The fan is broken
If any fan in the projector not move, broken, jam, the power light blinking 4 times after few second of power ON
SOLUTION: Remove the filter and then remove the upper cover
check fans and fan connector
if all fans are OK then remove the fan connector and reinstall
fix the cover and power ON projector
Feb 02, 2011 | Sony VPL-EX4 Projector
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Sony svga vpl-es2 won't work
Its because for the foot there is switch who give signal to micro processor or system control.Fix it that.Your problem will solve.
Jun 23, 2010 | Sony VPL-ES2 Multimedia Projector
Sony VPL-FE100 Fan Failing
Replace the fan and the fan motor. Most likely it is a internal problem with the fan
Feb 14, 2009 | Sony VPL-ES3 Multimedia Projector
Sony VLP-SC50 lamp shuts down and temp/fan light blinks
that means the fan is broken... say to call sony customer support. Probably gonna charge you an arm and a leg to fix it so im gonna try to nstall a new fam myself
Feb 03, 2008 | Sony VPL SC50 Multimedia Projector
Sony VPL-ES7 LCD Projector Logo
387 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
