I want to have black sidebars when i use de 4:3 aspect radio
SOURCE: sidebar
You need to go into the menu and reset the VIDEO to Full Screen. That should fix it. Good Luck and Good Weekend
Ed
NC Electronic
Mills, Wyoming
SOURCE: Have a Panasonic TH-50PX500U plasma TV. Color go's to blues
check and reseat all the connections on your T-con board which is located in the midle top of your unit there will be a cable from the mainboard and 1 or 2 from the top to the panel carful those connectors are cheap clean with rubbing alcohol
SOURCE: Panasonic TCP46C2 46 in Plasma
there should be a "format" button on your remote,just click it until you reach your desired ratio
