Question about White Sewing 1418 Mechanical Sewing Machine
How to thread a 1265 white sewing machine - White Sewing 1418 Mechanical Sewing Machine
SOURCE:
  • 10 Answers
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Posted on Jul 31, 2008
SOURCE: i need to find out how to load thread into a white heavy duty sewing machine model number 1866
actually they dont NOT TO THE WHITE 1886, I whoever is asking, I have the same problem. My own mother, and grandmother who have sown ALL their lives, who make clothes, etc. etc. CANNOT figure out for the life of us all, how to get that thing to load the thread., We get it through the needle, and underneath, And it looks normal, Its what you would do on a normal machine. But when you start, Is when it messes up. I think, they put up for sale because of this error
Posted on Aug 22, 2008
  • 9 Answers
SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Posted on Feb 02, 2009
bargainbox
  • 1388 Answers
SOURCE: For the White Mighty Mender W100 sewing machine,
Same as with all machines essentially.......
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 30, 2009
SOURCE: I purchased a White Sew
We had the same issue. The needle was facing left/right instead of front/back. Once I unscrewed the needle and repositioned it so that I could thread it front/back, I was able to get it to catch.
Posted on Dec 06, 2010
How do I thread White 8931 sewing machine?
A manual is always helpful to know how to use the machine and clean/maintain it. Your older mechanical machine probably needs a good cleaning and oiling (sewing machine only).
https://www.sewingpartsonline.com/instruction-manual-white-8931.aspx?
Some videos may be helpful. Not necessarily your particular, but the threading process is very similar between models. The top thread goes through some thread guides, the down around the tension unit, up to the take--up lever, back down through some other guides and then through the needle. This is where your owner's manual would be very useful.
White Sewing Machine 477 Model How To Thread Your Sewing Ma
I remember my mother traded in her Singer treadle for an electric White machine when I was a kid.
Mar 13, 2018 | Sewing Machines
How do I thread my white mode 742 also bobin thread is not picking up
Sewing Machine 101 The White 764
White sewing machine model 742 sewing discussion topic PatternReview com
Instruction Manual White 742
Even though the following is not your particular model, the process is very similar from one machine to another, so what you aren't able to get from the above links, you may get from these. Be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
White Sewing Machine 639 How To Upper Thread The Machine Vintage Metal
White Sewing Machine 639 How To Wind Bobbin Front Loading Bobbin Vintage
Nov 18, 2017 | Sewing Machines
How do I thread a white sewing machine model 1777 need step by step
You probably already have some documentation, but if not, here are some:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjG_4zKxZHNAhVDEVIKHYRXCCAQFggmMAI&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F1047_white-1077%2C1088%2C1099-x.pdf&usg=AFQjCNEneDdzHiLZoqEsll_eInKSdGrxgg&cad=rja
White sewing Machine model 1418 (not your model, but most machines thread very much the same)
When threading the machine, ALWAYS RAISE the presser foot during the threading process. This releases the tension disk so the thread will seat properly.
White 1735 Sewing Machine Instructional Video
Jun 05, 2016 | White Sewing Sewing Machines
I need to find a manual online for a White 1265 sewing maching.
go to http://www.singerco.com/accessories/manuals.html, search by typing "1265" into the search field and you should be able to download it as a PDF.
Apr 27, 2011 | White Sewing Sewing Machines
I have a model 1409A White sewing machine and I'm having issues with threading it. Something is going on with the needle and the bobbin. How do I fix it?
Thread the machine with the presser foot up - this opens the tension for the thread to enter and be controlled as you sew.
Threading with the presser foot down, closes the tension and the thread cannot enter during the threading process and you get loose, loopy stitches that appear to be an issue with the bobbin.
Feb 25, 2010 | White Sewing 1409 Mechanical Sewing...
Need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Feb 20, 2010 | White Sewing 1766 Mechanical Sewing...
Have an old white rotary machine # 151 or possibly #247
I have a few of the old White machines and it is never obvious as to how they are threaded. I found a YouTube video demo of a White and the fellow does a pretty fair job of showing how to thread the machine. I will include the link. https://www.youtube.com/watch?v=j9eiKXCjv80 Threading White Rotary model 43 sewing machine
Jul 09, 2017 | White Sewing Sewing Machines
Thread keeps breaking
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Aug 24, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing 1418 Mechanical Sewing Machine Logo
486 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
