Day date, just developed a problem that the second hand runs smoothly 2 per second and frequently falls backward between 6 to 12 as if the hand is loose on the shaft. if that is the problem can this be fixed by removing the crystal and pushing the second hand down on the shaft? Any other thoughts?
SOURCE: faux men's rolex date just
An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
SOURCE: ROLEX QUICK-SET FEATURE
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
-Mike
www.perfect-timing.biz
SOURCE: setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To
find the daytime or night time on the watch: pull out crown to the
second click and advance watch hands forward till you pass the 12 mark
on dial. If the date changes as you pass it - it is the night time
(midnight). If the date do not change as you pass it - it is the
daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
SOURCE: How to make the clasp on a Rolex 118238 president tighter
there is a little tab on the strap that need to be bent slightly to tighten the clasp. Most jewelers will do this for free.
