Model -- VGN-FS660\W
Problem : Not sure/NO clue..system is not starting...with power or without power..no light is displaying on the laptop when I am connecting to an adapter.
It is 13 months old laptop and I tried to call SONY support but those guys are asking 29.99 for a single query..
I would really appreciate if you can help me any way.
Thanks and Best regards,
Mark.
Possible power cable fault, hard to tell really, especially if you ran the laptop battery flat, but it may be a flat cmos (bios) motherboard battery, also check that the hibernate switch where you close your laptop lid is not stuck down as this will dissable power up.
I have the same problem and believe I have discovered the source of the problem. When I removed the back panel of the laptop, it started up just fine. I discovered that when applying pressure to the back of the board in the area of the hibernate switch, the laptop went into hibernate mode. If I kept pressure on the switch (simulating the back cover in place) I was not able to restart the laptop. However once I released the pressure, the laptop started just fine.
The switch seems to be spring actuated, designed to trigger the hibernate mode when the latch applies pressure against the switch depressing the spring. Apparantly the speing has failed thus resulting in the switch being engaged all the time.
I don't know if Sony makes a replacement switch but that seems to be what would solve the problem. I have learned one thing though, there is more built-in obsolecence in these machines all the time. I don't understand why they can't simply make a long lasting product for the $$$ we spend.
Have you got the latest direct x installed Open the run command from your start menu Type cmd in to the search window Type in 'dxdiag' and it will be at the bottom of the first page of the system tab
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem. Please let me know if you have any further questions or concerns. Thanks.
check your DC output voltage using multimeter. if you dont have a multimeter short circuit your power pin using a wire or paper clip. if that green light goes off your charging unite is working properly.
operating system not found
