I would love some guidance on how to access the inner mechanism and repair it. Anyone know how or know where to find an online guide or video?I have checked the Maytag site for a repair clinic for my model but found none. Someone else recommended opening up the panel, disconnecting the oven, sliding oven out a bit and propping up, etc. But, I can't unplug (can turn off power from breaker, though) and I can't slide and prop. It's too high up for that. I'll also remove my access if I do that.
SOURCE: How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
SOURCE: Maytag oven, top door has
Here is the body parts diagram of the Maytag CWE5800.So this will help you out in more depth.Please the link to so you can see other parts how it is linked to door too.
Click here to get to the body parts diagram.how to assemble it.
Hope this will help you,
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: I have a Maytag Gas
This could be a number of problems. It is very hard to tell you what the problem is without looking at the range. (916) 483-4341
Lamco Maytag Home Appliance
They should be able to help you.
SOURCE: We've got a broken door
My father-in-Law has the same issue and I found the spring as part of the hinge assembly. The link is "http://www.appliancepartspros.com/part_details.aspx?part_id=4092260&image=1" and the part number is Part Number: AP4092260
Made by WHIRLPOOL. Hope this helps!
