Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How do I link my desk top computer to Bizhub C350 to print
How do I make Bizhub C350 print from my computer
    New Friend:
  • 60 Answers
SOURCE:
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Posted on Jan 16, 2009
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
  • 158 Answers
SOURCE: How do I install Konica
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Posted on Oct 24, 2009
SOURCE: bizhub c350 print job hits copier never prints
  1. bizhub 350
Posted on Nov 18, 2009
I cant add my bizhub c350 to google cloud print
Mite try going to the konicaminolta website to see if they have any drivers for that machine. Mite be to old and best can windows 95 or XP.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 21, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Recent Driver Answer
kmbs.konicaminolta.us
In the top right corner you will find the downloads link. You will find all available drivers. The C350 is a older model and there my not be drivers available for newer version computers.
Apr 10, 2014 | Minolta C350 Printer
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
The bizhub c350 is printing 3 pages for every 1 sent to printer
it is a seting in the printer or the computer that can be modifeid to print from 1 to 99 or 999at every 1 sent to printer.
Nov 12, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Nov 11, 2008 | Minolta C350 Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
174 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
