Cell Phones Logo
Anonymous Posted on Mar 20, 2012
Looking for instruction book on pfaff1530 select
Duncan Mutch
Level 3:
  • Master 418 Answers
  • Posted on Mar 20, 2012
Duncan Mutch
Master
Level 3:
Answers
418
Questions
0
Helped
78248
Points
1268
How do i add a new number to my cellphone
frank select the menu button then go tothe address book select it then go to add new feel out all the feilds u can then select save ok
I would like to get a copy of the manual for the kenwood gourmet fp 310. Can you help please?
Available Instruction Books for Kenwood appliances may be downloaded from this site:
http://www.kenwoodworld.com/uk/Customer-Service/Instruction-Books/
I do not see a book specific to the FP310, however there may be an Instruction Book available for a model similar to the FP310 that could be of assistance.
Another option is to visit this page:
http://www.kenwoodworld.com/language/
Select your langage and go to the Customer Service Page. On the left side menu you will find a link for Instruction Books and/or Manuals. Check to see if your manual is available under your language.
If not suggest you make an inquiry via their Customer Service contact information:
How do i edit fax numbers stored in my machine
yep!
press "Function" key
select the fax settings on the screen
select address book on the screen
look for the name of the fax number you want to
change.
follow the instructions on the screen.
that's it!
1helpful
2answers
I started using Mac Mail today, moving from Entourage 11.4.0 to Mac Mail 1.3.11. I want to get my addresses across but have had no luck so far. I have hovered mouse over the email address and selected...
I think you mean adding email address to your account (importing email address), If you've set up the account properly, then there's not much difficultly, just follow the instructions below 1. Open the Address Book application. 2. Choose Import from the File menu. 3. Navigate to the file that you exported from your previous application and select it from the list of files. Tip: if you cannot select the file, the 4. Open button will not pulsate. This may indicate that the file is not in a format that Address Book can read. 5. Click Open. Your addresses (contacts) are now available for use in Address Book and all Mac OS X applications that work with Address Book.
On the other hand if you are importing addresses from previous version, the procedure is little different. Do let me know if you can't do with this. Good luck
Lost instruction book and would like to print another but can't find a manual online
Click the link below to select your product to download a PDF file of the manual.
http://www.magellangps.com/support/magellan_software_download.asp
or click the link below to download a Maestro 3220 manual
http://www.magellangps.com/support/product.asp
once on this page click manual-english link to download or you can also order a printed version. The way th page is made it looks like you can only buy a printed version. But you can download and then print.
4helpful
3answers
Samsung J700i mobile phone instruction book
go to phone pofiles in normal profile select edit then select key pad tone and pop-up alert tone turn both off
The books that came with my camera not in English
Contach http://www.pentax.jp/english/support and log on to English web site, Choice is at top of home page. Left hand side has download options, select download Manuals and the select form following menu S60 Manual.
INSTRUCTION BOOK
I was able to download the manual from www.vivitar.com
From their homepage
Select: Support
Select: Vicam 8400 Under "vivicam cameras"
Then another pull down menu shows up asking for the language you want.
Select your language, then click "Go"
Select: Manual (it's a number 1)
Look for a pop-up window asking you to save it or open it. I recommend saving it to your desktop. The manual is in PDF. Do you have PDF?
By the way it took me a couple tries to get it download.
The main problem is the instruction Book and the K800i Phono
Just type the number including the country code, then
select More on the right hand side of the phone,
select Save number, and then,
choose an already saved contact to add the number to,
or create a new contact,
then click Select on the left hand side of the phone,
then the phone will prompt you to put a name in for that number. if it's a new contact.
Then select Save.
1helpful
2answers
Delete music
Instruction book should be on the computer you set up the MP3 player.Go to my computer look for guide under the drive selected for setup the manual you're looking for will have the name H106 it will be in the adobe reader.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
