Panasonic TH-42PZ700U 42 in. Plasma Television Logo
Anonymous Posted on Mar 20, 2012
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button is just blinking. What can I do?
Duncan Mutch
Level 3:
  • Master 418 Answers
  • Posted on Mar 20, 2012
Duncan Mutch
Master
Level 3:
Answers
418
Questions
0
Helped
78231
Points
1268
All you can do is: Take the plug out of the wall (power) - wait 2hrs, plug in and try again. If it will not work after being cooled and the capacitors drained (which this will do) then it needs repair.
5 Related Answers
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Dec 09, 2008
SOURCE: Flashing red light 7 times on our panasonic th-42pz700u
hello you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd boards
10th generation plasma service manual info
Anonymous
  • Posted on Feb 22, 2009
SOURCE: Panasonic TH-42PZ700U Won't Turn ON.
ITS A CODE WHEN THE RED LIGHT BLINKS
Anonymous
ITS GOT TO DO WITH THE INSIDE OF THE TV 1 OF THE PWER BOARDS ARE BAD
Anonymous
  • Posted on Oct 06, 2009
SOURCE: Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Chi Chu
  • 8457 Answers
  • Posted on Mar 04, 2010
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
My Panasonic TH-42PZ700U 42in. TV doesn't turn on anymore. The red power light blinks 7 times. I hold down the power button until it stops blinking. When I let go of the button, the red power light stays...
2helpful
2answers
Panasonic TH-42PZ700U 7 blinks
Remove the back panel. Blow out the dust with compressed air and then vacuum.
TV power light blinks 7 times and won't turn on
your sc bord is shot replace board and do firmware upgrade will coast about 400
PANASONIC TH-42PZ700U - WILL NOT POWER UP
THIS SYMTOM MEANS THERES A POWER PROBLEM DEPENDING ON HOW MANY BLINKS WILL TELL YOU WHAT BOARD OR PANEL IS BAD OR NEEDS TO BE CHECKED IT MAY BE A BLOWN FUSE
COUNT THE TIMES IT BLINKs and i can tell you what internal circut board is bad..
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
