Yahoo Diamond Vision DVDC803-04 DVD Player Logo
RLBR Posted on Mar 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Great picture but really loud static when watching dvd
Do not have a remote for the tv and was watching a dvd...something got pressed on dvd remote or tv and now get a really loud static noise when trying to watch anything on dvd.
Anonymous
Level 3:
  • Master 6,771 Answers
  • Posted on Mar 20, 2012
Anonymous
Master
Level 3:
Answers
6771
Questions
0
Helped
1777329
Points
21413
Hook the DVD to another TV set, this will prove if the player is the issue or original TV
5 Related Answers
Anonymous
  • Posted on Jun 02, 2007
SOURCE: portable mustek dvd player
try this: power up your dvd without a disc. using your remote keypad input 9735. a secret menu should apprear. select your region code or choose 0 which will allow all discs to play. this will work with the mp70c but not with all mustek models. other solutions are available with an exhaustive google search
Anonymous
  • 47 Answers
  • Posted on Mar 08, 2008
SOURCE: watching tv while recording onto vhs or dvd
In order to view one channel and record another, you have to have (and be using) two tuners and also have a way to bypass the signal to one tuner into the other. The only time you're using the tuner of a device is when coaxial is connected - everything else is an input mode.
1. You could have a 2-way splitter with the signal connected on one end to RF IN of the DMR and on ANT IN of the TV, then the DMR connected to the TV via composite, S-Video or component cables.
2. You could connect coaxial all the way through to the television from the wall. Wall to DMR to TV - all coax would allow you to view one channel and watch another. Tune the DVD recorder to the channel you wish to record and start the recording. Use the TV/VCR button to bypass that signal to the TV and tune the station you want to watch on your television.
When it says "you cannot change the channel or recording mode while recording" that is referring to the tuner on the DVD recorder, not your television. I think the issue here is that you're keeping your TV in the input mode and trying to change the channel on the recorder after you've started recording - but I could be wrong. You need to change the channel on the TV ITSELF.
A
Anonymous
  • Posted on Apr 30, 2008
SOURCE: Picture only shows in black & white when playing DVD
I had the same issue. Just disconneted the S-VEDIO and now using the vedio connected and color start showing again
Anonymous
  • Posted on Aug 19, 2008
SOURCE: Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Anonymous
  • Posted on May 09, 2009
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
3answers
DVD video showing without DVD in
have you tried pressing the dvd button twice on the remote?
Color on TV changes to black and white, then after awhile changes back
It is possible to be the box, and not your tv. A good way to test is to see if it does it when you are watching a dvd or another source. (game system, blue ray, ect) Hope this helps! Good luck!
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
2answers
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
3helpful
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Top Yahoo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
