Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
Posted on Mar 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony trintron is stuck in stand by mode - Sony FD Trinitron WEGA KV-27FS120 27" TV
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Mar 20, 2012
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715347
Points
48227
If model number listed here (kv-27fs120) is correct the set if not coming on is in shutdown because either a problem in its power supply or something elsewhere pulling the supply voltages down and triggering shut down.
Someone would have to open and first check for voltages and or shorts--no real other easy way to troubleshoot this.
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Tv wont turn on and the stand by blinks 2 times pulse 2 times sony Trintron KV-24FS100
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. This is the fault. There is over voltage from the voltage regulator section inside. You have to check out the reason for that. In most cased, the will be due to some loose solder terminals at this section.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there. Check the site, and see whether it can help you.
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
My sony trintron tv is not turning on i got just the stand by botton blinking
There could be a shortage in your power supply so you change the power supply or it be the power cord for your tv
I have a 36" Sony FD Trintron won't turn on and no sound
Have you tried unplugging it from the wall for a couple of minutes, this may reset it.
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
2helpful
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
