Acer Aspire 3000 Notebook Logo
Posted on Nov 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless adapter radio
The computer says the wireless radio is turned off. How do i turn it on
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 275 Answers
  • Posted on Nov 05, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
275
Questions
0
Helped
95876
Points
603
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon wireless adapter radio - prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
2helpful
2answers
Wireless radio on Lenovo Y510 turned off even though the slider switch is switched on and lights up. How can I turn on wireless radio?
Hi There and Welcome to Fixya!
Another way to turn on the wireless radio on your Lenovo Y510 is to press and hold the "Fn" key, then simultaneously press the "F5" key.
This is an alternative way to switch the wireless antenna on or off without using the physical WIFI switch.
Hope this helps,
Thank you for using FixYa.
1helpful
Cannot turn on wireless radio on Lenovo Idealpad
Press FN+F5 button together on the keyboard to have the settings for display pops up on the screen. Check if the radio button was turned on both for wireless and bluetooth connection. If the radio button was off, just click ON and that should set the wifi to turned on. Always make sure that the wifi switch was set to on as well.
If this didn't fix the problem, kindly reinstall the wifi adapter driver by downloading the driver from the manufacturer's website. after reinstallation kindly reboot the computer.
Please leave comments if you have any other questions.
Cheers~
Where is the wireless radio button on an old HP Pavillion 8705? I just installed a usb wireless adapter and now I'm running the Linksys Add a computer to your wireless network wizard, but the message tells...
On desktops, that's usually software controlled, not via a button.
nce you have the right software installed for the usb adapter for your operating system, there should be an icon in the system tray where you can activate the wireless feature.
I stress for your operating system because I had to get a new adapter once because i couldn't find vista or windows 7 drivers for my old adapter which I used with windows xp.
1helpful
How do I turn the radio on the wireless card
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Hope this helps !
Wireless connection problem
Right click,on my computer,Click properties,click device manager (on the left),Click the Network adapter,Click on the wireless adapter and click enable.Then turn the wireless radio off and back on as you have done before or just restart the computer.
2helpful
Intel PRO/Wireless is turned off and I need help turning it on.
just go to Network Connection >>right click Wireless Adapte>>Enable.
if doesn't work try to uninstall the Wireless NIC from the Device Manager, go to Device Manager>>Network Adapter(expand)>>Right click on wireless adapter>>uninstall.
once done, click on Action Menu on the top and click on Scan for hardware changes. It would automatically detect the wireless card.
then try to use it, it should work fine :)
Regards,
Askari
[email protected]
Radio Turns Off
re-installed it the adapter and disable the firewall in the computer
Wireless internet conxn
try to look for a wireless switch on the computer. Sometimes, the wireless switch is located on the side or on top of the function keys (it sometimes shows as a slide switch or a button with a radio signal/ radio waves).
You can try to contact your computer manufacturer to ask where the wireless switch on the computer is located.
I have a notebook model # MA6 NX560X Want to take it to Aruba. What do I need? ISit WIFI ready? I can buy a card down ther for access. Thanks Barbara Rant [email protected]
According to the spec sheet from gateway it already has a intel-pro wireless adapter installed to verify go to start,right click on my computer, left click on properties,left click on hardware, left click on device manager, left click on the + plus sign by network adapters and if the wireless network adapter is listed it is installed.
Q: How do I turn my notebook's wireless on and off?A: To turn the wireless radio on or off, press FN+F2. The wireless status indicator turns on or off.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
