HOW TO EMPTY THE WASTE TONER BOTTLE FOR THE LANIER LD445C COPIER FAX PRINTER?????
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side cover must come off. probably a service call will be needed
SOURCE: How do i empty a waste toner bottle on a lanier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
